Fuel line clips saph?
Yes,ford still stock them.
There's 4 different types,think there's 5 the same as in the pic above,1 that's different from the rest on the rear floorpan before the pipes bend up towards the chassis rail then 1 with a big fixing for the chassis leg,where the plastic pipes go under the rear crossmember towards the tank/pump there are 2 or 3 double white clips.
meandmymonkeymatt on eBay does them all I think.
All available from ford but it could be easier getting them from eBay if your parts guy is no use.
mrmann
Oct 17, 2015 04:01 PM
