Sierra solid beam mounts
Old Nov 4, 2015 | 06:01 PM
2wdsaph ben's Avatar
2wdsaph ben
Default Sierra solid beam mounts
I've seen plenty on here about them so thought I'll get my self a set from fordrallycar for my sierra as the rear feels so sloppy, hopefully drop the rear beam at weekend and start removing the old rubber bushes.so far very impressed as they are cheaper than the equivalent poly bush and won't wear out or Soften up
I'll update with more pics when they are fitted as fitting this and painting rear beam up at same time
Old Nov 4, 2015 | 06:15 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Just fitted a set to mine it went together really well other than needing a small amount of welding on the chassis leg after removing the beam. These are mine fitted
I also have the same type of diff hanger
Old Nov 7, 2015 | 04:13 PM
2wdsaph ben
That looks really smart under there mate. Going to have a little go at cleaning up my rear axle assemble a bit and a lick of paint. Nothing major as don't want to replace the trailing bushes or the wheel bearings
Sean83
Nov 7, 2015 04:17 PM
henrydickens
Ford Fiesta
Nov 5, 2015 04:06 PM
nath69uk
Nov 2, 2015 08:53 PM
bull-turbo
Nov 2, 2015 05:57 PM
2wdsaph ben
Nov 1, 2015 09:40 AM
