3dr header tank standard
Old Nov 4, 2015 | 08:38 AM
martynhomer01's Avatar
martynhomer01
Default 3dr header tank standard
What would I expect to pay for one of these in good condition please guys?
3dr expension / header tank
Old Nov 4, 2015 | 09:19 AM
R4N SS's Avatar
R4N SS
prob around 70-100 i reckon
Old Nov 4, 2015 | 05:29 PM
JasonPD's Avatar
JasonPD
I did see one sell for Ł1500 on fleabay but I can't believe someone would actually pay that for one..?!
I know the suggestion for a 2wd is to use a 4x4 one and get a different hose
http://www.ebay.co.uk/itm/2207430411...%3AMEBIDX%3AIT
but how does it work for a 3dr as the 3dr uses the same tank as the 2wd but the 2wd has the sensor thing blocked off?
Old Nov 4, 2015 | 06:47 PM
bigdel's Avatar
bigdel
I'd say a really good condition one would set you back Ł150+
Old Nov 4, 2015 | 07:18 PM
dave cos4x4's Avatar
dave cos4x4
more if you can get one Martyn.
Old Nov 4, 2015 | 07:33 PM
PAUL S's Avatar
PAUL S
Not a chance of finding a decent, clean, non bloated one for under Ł400 and even then it will have visible splits and cracks and a new one would be Ł1k plus if you could find one that is.
If its not a show car better off using a new 4x4 one from ebay for Ł70 odd quid, they look the part and I can sell you the proper Ford rubber hose to connect it for Ł25
http://www.ebay.co.uk/itm/3316865407...84.m1555.l2649
Old Nov 4, 2015 | 07:45 PM
martynhomer01
The reason I ask is I have a non bloated non stained one! Don't know if it's worth keeping or selling as I have a Bailey header on mine��
Old Nov 4, 2015 | 10:41 PM
Tim Wharton's Avatar
Tim Wharton
I put a 4x4 one on my 3door when I had it
I used a bolt in tyre vavle to make a union for the standard turbo hose
Then removed the metal tube from the lower 16mm outlet machined down a 3door water level sensor so it was a tight fit bonded it in with a nice stainless hose clip round the bottle outlet just to make sure it didn't come out
Looked pretty neat
Cheers Tim.
Old Nov 5, 2015 | 04:07 PM
R4N SS's Avatar
R4N SS
the standard header tanks are shit anyway as they expand and split. Better off using a stainless header tank.
But then again i've never been into standard cars
Old Nov 5, 2015 | 05:11 PM
martynhomer01
Lol. I'm trying to stay a standard as possible but...........
Old Nov 6, 2015 | 02:23 PM
R4N SS's Avatar
R4N SS
Why? when you know the header tank will split eventually. They only look good whilst they are clean.
I would be using a stainless item and keep the standard header tank for when you do decide to sell it.
Old Nov 6, 2015 | 07:41 PM
bodace5's Avatar
bodace5
Id like to put a standard one back on my 3dr because as a mechanic i like to see the colour/condition/level of the coolant when ever i pop the bonnet
Old Nov 7, 2015 | 07:36 AM
cossynut2's Avatar
cossynut2
10 Year Member
You can get stainless steel ones with a fluid level sight glass.
Old Nov 7, 2015 | 07:44 PM
martynhomer01
Old Nov 7, 2015 | 08:38 PM
Mr RS500's Avatar
Mr RS500
I have just fitted one almost identical to that on a black rs500 i have just restored ( it had an ally item when it came to me )
I charged him Ł250 for it
https://www.facebook.com/northyorksh...nf&pnref=story
Old Nov 7, 2015 | 10:32 PM
gcfcos's Avatar
gcfcos
Yeah this is why I've never fitted a stainless one as I like to see all my levels at a glance. Mind u I can understand the metal ones being stronger but I just like the standard tanks
Old Nov 9, 2015 | 03:33 PM
R4N SS's Avatar
R4N SS
it only takes two secs to open the cap and check the coolant or get one with a sight glass.
As soon as you run any decent boost the sytem pressurises and the bottle expands - fuck that
Old Nov 9, 2015 | 04:15 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
My spec r one has a nice window right down the front easy to see the coolant at a glance
Old Nov 9, 2015 | 06:07 PM
gcfcos's Avatar
gcfcos
U have boost running through your cooling system lol? If the engines hot your not
Gonna start undoing bottle caps, it's nice to pop the bonnet and see at a glance what the coolants doing.
I'm only joking by the way lol
Old Nov 11, 2015 | 02:40 PM
R4N SS's Avatar
R4N SS
lol you know what i meant - im no mechanic lol
Old Nov 11, 2015 | 02:57 PM
Adam-M's Avatar
Adam-M
When I bought mines it had a horrid chrome baileys one with no sight and when I slackened the lid to look inside there was no coolant in the bottle so bought a brand new plastic one from eBay instead. Looks better imo it does swell up on hard driving but I'll try a swirl pot to see if that helps.
Old Nov 11, 2015 | 03:29 PM
R4N SS's Avatar
R4N SS
I dont think a swirl pot made much difference to mine hence going ally in the end
Old Nov 11, 2015 | 04:52 PM
gcfcos's Avatar
gcfcos
Lol yeah I know mate, the heat generated in some of these high boost cars I don't expect plastic tanks would last 5 minutes, especially 1980s plastic
cossie4i+
37
Nov 17, 2015 08:03 AM
bodace5
Oct 17, 2015 05:23 AM
martynhomer01
14
Sep 23, 2015 12:23 AM
bigdel
Sep 22, 2015 05:50 PM
