Fiesta mk2 Zetec Turbo
Hi
I thought i would make my own project thread, so i could get opinions and advices from here.
I have been building this car allmost four years.
It started as simple engine conversion from 1.0 to 1.6.
At some point came 1.8 zvh turbo and then full zetec turbo.
Current specs:
1.8 zetec
Wossner pistons and Eagle rods
Ported and polished head (by myself)
Focus RS inlet manifold
870cc Deka injectors
Home made exhaust manifold, 3 inch downpipe and exhaust system
Garrett T28 turbo
Megasquirt engine management
Dynoed 302hp 458nm at 1.0bar boost
Mtx-75 gearbox with Quaife diff
Clutchmasters paddle clutch and pressure plate
Aluminium flywheel
Custom made driveshafts
Modified Puma gear linkage
Gaz gha coilovers
Xr2 anti-roll bar
Rose jointed panhard rod
Sierra cosworth front calibers and rs2000 discs
Standard xr2b rear brakes
Motec 15" rally wheels
Federal semi slicks
Weld-in rollcage
Bucket seats and four point belts
Stripped interior
Future plans are to improve handling, car is mainly build to track.
Maybe Time attack series in next summer...
I'll upload more photos soon.
Hope my spelling isn't too bad
Current specs:
1.8 zetec
Garrett T28 turbo
Aluminium flywheel
Gaz gha coilovers
Xr2 anti-roll bar
Federal semi slicks
Weld-in rollcage
Stripped interior
Welcome PF, there is never too much car builders from Finland in here
I´ve kept this one on eye earlier, and I still gotta say that is great to see so much of your own work in the car, espcially with rollcage and that zetec turbo conversion.
BTW does the rules in time attack allow weld in mounts to bodyshell? If I had understood it correct in rally (according AKK) those mounts to bodyshell had to be done by bolts.
Anyway good luck with rest of the built
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
dirty-diesel
Sep 29, 2015 07:25 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
