Wheels and Tyres Wheels and Tyres for all Ford's
Mk3 wheels on a Mk2
Old Nov 2, 2015 | 10:06 AM
Sp3no's Avatar
Sp3no
Default Mk3 wheels on a Mk2
Will genuine ford 18" alloys from a Mk3 focus fit a Mk2? I know PCD is same just thinking of the ET
Old Jan 20, 2016 | 12:32 PM
Sp3no's Avatar
Sp3no
Just as a bit of an update, I now have a set of 2014 Ford Y spoke 18x8" rims fitted to my MK2 Focus with 225-40-18 tyres. Although they do physically bolt straight on there is a small issue. Because of the depth of the rim my standard studs were too short only allowing around 6 turns on the wheel nuts. I ended up fitting +20mm Wheel studs to the front with 10mm hubcentric spacers and 20mm hubcentric spacers to the rear that came wit +10mm longer studs. All good now but not a straight fit by any means. Took the oppoutunity to lower her on Eibach Springs too so she sitting pretty now
Mr S1
Alloy wheels and ICE for sale
Jan 31, 2016 07:19 AM
cossie09
Dec 9, 2015 03:45 AM
deanflowers
17
Nov 23, 2015 10:04 PM
jan247uk
Nov 2, 2015 10:15 PM
salsheikh
Nov 2, 2015 10:18 AM
