What do people think of this sump?
Old Nov 1, 2015 | 06:26 PM
little bram's Avatar
little bram
Default What do people think of this sump?
Hi all two things am just trying out my photobucket and second is I've just had this done by a Company that mainly builds Subaru rally cars so they don't work on sumps like mine but give it a go anyway my only worry been the oil returning to the pick up quick enough. They said the oil will go down the sides back to the pick up.
[URL=http://s382.photobucket.com/user/littlebram1/media/Mobile%20Uploads/B4D33CC8-C6BC-40F8-AADB-BF6DE3884974_zpszs7slymj.jpg.html]Name:  B4D33CC8-C6BC-40F8-AADB-BF6DE3884974_zpszs7slymj.jpg
Old Nov 1, 2015 | 06:29 PM
lacey's Avatar
lacey
I will be very suprised if you get enough oil back to the
Pump like that
Old Nov 1, 2015 | 06:40 PM
little bram
They said they didn't put holds in the plate as that would defeating the object of want we are trying to achieve. I was thinking of putting some holes in the centre?
Old Nov 1, 2015 | 07:29 PM
lacey's Avatar
lacey
Are u still using the genuine baffle/wind age plate that bolts to the main caps ?
Old Nov 1, 2015 | 07:35 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you will never get enough oil back ot the pick up
if anything that's going to make maters worse rather than better, even the baffle on the bottom hasn't got any holes init to let the oil back in from the top of the sump
Old Nov 1, 2015 | 07:58 PM
little bram
Yeah was going to fit the wing tray as well.
Old Nov 1, 2015 | 08:00 PM
frsjon's Avatar
frsjon
heres a raceline one for comparison
Old Nov 1, 2015 | 08:07 PM
lacey's Avatar
lacey
Firstly if there is no oil down low then there is not going to be a engine
So you need a gap all round by about 6/10 mm
I would also get a recess pressed in the middle and put a hole in the
Centre of that to
Also lift the end that is down on the pan by 3/4mm
The baffle in the bottom of the pan needs a few half round holes
At the bottom To let the oil move to the pick up .
as at the mo your going to do a good job of
Keeping it away
little bram
There is holes in the baffle plate at the bottom the picture doesn't show them. I've try poring oil in to see what happens but I don't the poring 4 litres of oil in was a good enough test really.
Old Nov 1, 2015 | 08:13 PM
lacey's Avatar
lacey
I see them now
A little small tho
Old Nov 1, 2015 | 08:21 PM
little bram
Is this your sump? This is what I was thinking of to this plate like them holes it that one.
Old Nov 1, 2015 | 08:24 PM
little bram
I see them now
A little small tho
Haha yeah they are there I am still thinking of getting the later black top sump.
Old Nov 1, 2015 | 08:38 PM
frsjon's Avatar
frsjon
it was mate but i sold it as it was for a rwd zetec sadly. the pics done show it but its big winged and would of played havoc with the driveshafts
Old Nov 1, 2015 | 08:42 PM
little bram
What sump you running now mate?
Old Nov 1, 2015 | 09:12 PM
Chas's Avatar
Chas
Has anyone fitted a 2 part Zetec sump to a ZVH/Zetec on a BC5 Gearbox? What mods have to be done for it to fit?
I know ZetecInside reckons a stock sump is fine but a recent trackday seemed to prove the opposite.
Old Nov 2, 2015 | 05:07 AM
little bram
I think you've got to cut some of the webbing out of the sump to get them to fit am not 100% on that mind.
Old Nov 2, 2015 | 10:24 AM
dojj's Avatar
dojj
i'm no expert but the holes look to be a little small, plus the main baffle has no space for the oil to run back into the main part of the sump which would be my main concern
what car is it going on as it looks like there is something attached to the baffle plate
Old Nov 2, 2015 | 11:20 AM
lacey's Avatar
lacey
Correct
Worth while doing
Old Nov 2, 2015 | 05:27 PM
Chas's Avatar
Chas
Correct
Worth while doing
Are you OK to go into more detail about how this can be done and if there are photos showing what needs to be altered? This sounds appealing since it would be cheaper than baffling my existing sump.
I am hoping that by doing a couple of things my oil surge issues and losing alot of oil around hard bends on trackdays will become a thing of the past.
Old Nov 2, 2015 | 06:32 PM
Chopshop85's Avatar
Chopshop85
Fitted one to a IB5 box which is the same deal.
Cut both the sump wings off, trim away a bit of webbing on the front to allow the starter motor to fit. Then i had to weld some extra plate onto the gearbox sandwich plate (which needed trimming in a few places) as where the starter would be on a zetec was just a big hole to the back of the flywheel.
Old Nov 2, 2015 | 07:30 PM
little bram
So the webbing you's are talking about is on the front for the start motor? I wasn't sure what you's where going on about.
Old Nov 2, 2015 | 09:01 PM
studabear's Avatar
studabear
Old Nov 12, 2015 | 07:29 AM
muz's Avatar
muz
Wye Valley Hardcore
I didn't think you could use the two-piece sump with a standard downpipe, though?
Old Nov 12, 2015 | 07:39 AM
Chopshop85's Avatar
Chopshop85
I found mine needed modifying slightly as it was a bit close to the back edge of the sump.
Old Nov 12, 2015 | 05:36 PM
Chas's Avatar
Chas
Don't say that! I was looking forward to a cheap fix!
Old Nov 12, 2015 | 05:45 PM
studabear's Avatar
studabear
Mine was ok, as far as I can recall.
Old Nov 12, 2015 | 07:18 PM
Chopshop85's Avatar
Chopshop85
My downpipe has seen a few speed bumps in its time which probably doesn't help .
Although I found once I had made my engine mount and using a manifold adapter plate my downpipe needed to be 1-2cm longer so I used this as an opportunity to add some clearance to the sump.
Incase you can't guess, I'm very anal when it comes to these things.
Old Nov 13, 2015 | 06:32 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
there are big wing cvh and zetec sumps on offer on other websites.
Have a look and see decent baffles and gates been inserted to get an idea what is perfect for a track or race car.
Old Nov 13, 2015 | 08:44 PM
little bram
Where in these other websites do I need to look?
cossie09
14
Dec 9, 2015 09:55 PM
cossie09
Nov 15, 2015 06:13 PM
Ellsa
20
Nov 12, 2015 02:39 PM
dalmarshall
18
Nov 2, 2015 08:12 PM
Beach
Nov 1, 2015 06:03 AM
