St170 project
Old Nov 1, 2015 | 04:51 PM
danboy900's Avatar
danboy900
Default St170 project
Can anyone help me Im trying to get a st170 running with original loom and Ecu I've got it to start but cuts out straight away any ideas
Old Nov 1, 2015 | 04:54 PM
RichieST's Avatar
RichieST
Is the fuel pump priming when you turn the ignition on?
Old Nov 1, 2015 | 05:00 PM
danboy900's Avatar
danboy900
The fuel pump is priming up
Old Nov 1, 2015 | 06:09 PM
RichieST's Avatar
RichieST
Check the pump stays running when cranking and when the engine is running, there is a fuel pressure sensor on the rail that isn't uncommon to fail, the pumps do fail on them too.
Have you checked for any fault codes?
Old Nov 1, 2015 | 06:28 PM
danboy900's Avatar
danboy900
I've got the engine out of the car with it all wired up to the original loom and Ecu will try and get it plugged in to see if it throws a fault up
RS 5tu
17
Nov 5, 2015 07:39 PM
cossie09
Nov 2, 2015 12:34 PM
DixieTheKid
Oct 29, 2015 09:43 PM
Tank Mike
Oct 28, 2015 07:55 PM
Steve Escos
Oct 26, 2015 11:07 AM
