Zetec Turbo Boost pipes.
Making up the pipe work for my zetec turbo.
Is there a certain size I should keep the pipes?
The inlet is 83mm and the IC take off is 52mm. Would I be ok running 70mm hard pipe between the two or should I keep the pipework smaller?
