I've just bought a genuine weber 3 bar map sensor off fleabay. It says it has been tested and is in perfect working order. how can i check this for myself? I fitted it straight away and tested the car. And it is backfiring under load. Worse then the brands hatch 3 bar map sensor i had on before hand.
The code on the side of the sensor is SPA05/01 1769 if that means anything to anyone.
