Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Focus engine system fault
Old Oct 22, 2015 | 04:29 PM
Daviehastings's Avatar
Daviehastings
Default Focus engine system fault
My 07 focus 1.6 tdci is getting engine system fault. Comes on after about a minute of starting car, and goes into limp mode. Also this morning the bonnet would not open, key just turns and does nothing. Please help. Thinking it's going to cost fortune to fix.
David
Old Oct 24, 2015 | 09:19 PM
Supercmaxer's Avatar
Supercmaxer
Disconnect the battery for 30mins it's meant to reset the systems. As for the bonnet lock, the plastic clip that holds it in place may have snapped off. Does the key turn or the lock?
Old Oct 24, 2015 | 10:59 PM
mk3ste's Avatar
mk3ste
Have it plugged in but two common faults are glow plug relay or glow plugs normally
Bonnet lock replacement is about £40 from fords but you can use your original barrel to save building the new barrel up
If your going to do it yourself pm me and I can or will try to talk you through gaining access to getting the bonnet open
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
sridgett
Oct 1, 2015 07:30 PM
Sp3no
Sep 27, 2015 07:23 PM
sridgett
13
Sep 27, 2015 06:03 PM
