200 block with 2wd internals
Old Oct 19, 2015 | 07:45 PM
timsrs's Avatar
timsrs
Default 200 block with 2wd internals
I have the chance to purchase a good 200 block.
Will all the 2wd internals fit into the 200 block.
such things like...
OIL PUMP / SPRAY BAR
SUMP WITH PICK-UP PIPE
RODS / PISTONS
CRANKS
many thanks
Old Oct 19, 2015 | 07:53 PM
jamie956's Avatar
jamie956
such things like...
RODS / PISTONS
CRANKS
many thanks
Yes will all swap straight over, you should consider getting the block long studded while its apart and cut outs in the pistons, future proofs the engine for not a lot of money.
Old Oct 19, 2015 | 08:14 PM
timsrs's Avatar
timsrs
Yes totally agree with you.
I am looking for more power than my 380bhp at the moment on the 205 block.
If i use all the 2WD internals i take it i will still get some piston slap due to the centre pin location.
I am so happy that all the small things will transfer over.
I know i will have this answer when i strip the engine down but i did thinkthe pumps were different and the pick-up due to sump.
Old Oct 19, 2015 | 08:20 PM
jamie956's Avatar
jamie956
Yes pump and pick up different block the same, what power you going for next.
Old Oct 19, 2015 | 08:26 PM
timsrs's Avatar
timsrs
To be honest i'm not going to be chasing any figures, but would like to see anything above 500.
If it turns out 470 i'll still be happy.
i will do alot of research when i get deep into the build.
i have a very good engineering company that will do the machine work for me.
Whats your opinion on 500 bhp engine ?
Regards
Old Oct 19, 2015 | 08:32 PM
jamie956's Avatar
jamie956
Guess it depends on what your doing with car is this for your mk1.
Old Oct 19, 2015 | 08:35 PM
timsrs's Avatar
timsrs
Yes its for the Mk1...
Fast ( well very fast ) road car.
Doing a few changes to suspension over the winter also.
Old Oct 19, 2015 | 08:49 PM
jamie956's Avatar
jamie956
I think to run at 500 and use all of it is not cheap, std t5 and a atlas is on borrowed time with 500bhp, my Cortina with a t34 at 390 spins in third on 245 cr500's so bigger wheels & rubber to get it down.
Engine wise for 500 your looking a 10 studs and cp pistons, head work, a cam or cams, inlet, 83lbs injectors, big intercooler, decent boost control and ideally after market ecu.
Then a high spec t38 or gt30 unless you got the budget for a BW and manifold.
Old Oct 20, 2015 | 09:31 AM
timsrs's Avatar
timsrs
My car is 6 linked running same size tyres as you, and to be honest puts the power down really well.
It just squats and goes ( wont spin up in third ) just pulls really hard.
The atlas has been built to handle 500bhp with the motorsport LSD..
T5 could be an issue though.
Ford Focus ST Parts for Sale
Oct 19, 2015 02:32 PM
bigdel
Oct 18, 2015 08:47 AM
timsrs
Oct 17, 2015 09:05 AM
Kam B
Oct 16, 2015 11:07 AM
