Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
What mods can i do to fiesta mk2 1.1
Old Oct 14, 2015 | 06:37 AM
Hendred's Avatar
Hendred
Default What mods can i do to fiesta mk2 1.1
Hi all,
I have seen a fiesta mk2 I want, just wondering what I could do to it for firstly looks (lowering, allloys), noise (exhaust) and then performance (engine)??
Was on the Mini scene but just fed up with it, want a car I want and like not what is easy to get parts for which was my reasoning.
Any advice would be great, thanks John
Old Oct 23, 2015 | 02:43 PM
BLU's Avatar
BLU
BLU is the new black :)
How long is a piece of string
First job, get underneath and check for rust (boot floor, inner and outer sills, inner wings etc) and get anything crusty rectified.
Lowering is fairy straight forward - I'd buy a full set of springs and shocks and I'd replace all the bushes at the same time as they are probably past it now! Full geo will see it handling like a go-cart!
Wheels, you're limited by the size of the arches. Anything over 15" in diameter looks a bit soft and anything over 6.5" wide will need arch extensions!
Looks - depends what you want, you could keep it OEM with some XR2 parts or go balls out with an aftermarket bodykit!
Not sure whats available exhaust wise for the 1.1 but anything XR2 could be modified to fit the 1.1 downpipe I'm sure.
Old Oct 23, 2015 | 04:11 PM
Hendred's Avatar
Hendred
That's really helpful, thank you
Old Oct 23, 2015 | 04:19 PM
lacey's Avatar
lacey
Buy a 1.7 vvct puma for next to nothing and gut it and put it in to your car
Nice very cheap little rocket
Old Oct 23, 2015 | 04:48 PM
Hendred's Avatar
Hendred
Puma engine fit a mk2 fiesta?
Old Oct 23, 2015 | 05:15 PM
BLU's Avatar
BLU
It does but its far from an easy fit, however not impossible. The 1.6/1.8/2.0 Zetec engines are easier to fit, you can run the standard ford ecu or aftermarket system like Megasquirt or similar!
Don't forget to update your brakes too if you go for a more powerful engine
Old Oct 23, 2015 | 05:43 PM
Hendred's Avatar
Hendred
I will defintely have a think about that, thanks
Old Oct 23, 2015 | 06:06 PM
Ben26's Avatar
Ben26
I bought a puma so I can chuck the engine into my mk1
Should be good fun to do and drive
Old Jan 19, 2016 | 08:07 PM
sridgett's Avatar
sridgett
The only way is dagenham
Originally Posted by Hendred
Hi all,
Hi mate, dunno if your still after help with your mk2. I also have a mk2 1.1 so hopefully I can help out.
First off as for looks the mk2 is a nice little motor, you can make it look different buy fitting ghia bumpers or just painting the standard ones, as for wheels all classic ford wheels fit( apart from Granada wheels) If you want a "old skool" look maby some 6x13 4 spoke rs wheels (like those on a capri laser) pepperpots also looks good and where fitted to the mk2 xr2. Lowering is pretty simple as its a basic car. A set of xr2 springs will give it a nice ride height if you want lower there you can get the springs from Burton power. As for exhaust you could ways do it the cheap way and fit a cherry bomb. How ever back in the day there where series x kits available for the 1.1, different carb, intake , exhaust etc... they give a decent power upgrades over the std motor. But hard to find now. So you need to get lucky on ebay As for engine swaps you could fit the 1.3 version of your engine or a 1.6 crossflow from a mk1 xr2, this will keep it period looking under the bonnet. Then there are the 1.4 and 1.6 cvh engines, a pretty basic fit and the 1.6 will make 120 Bhp with out much work. Then there is the zetec. This can be a big power engine that will mate your car bloody mental, harder to fit though.
Hope that helps
Old Jan 20, 2016 | 07:22 AM
FORD RS MAD's Avatar
FORD RS MAD
Ford model mad
I had a Mk2 1.3 Ghia for a while, lowered -40 mm with H&R springs, 13" rims and 175/50/13 tyres, really could of done with 14" rims and a lower drop. Had a Ashley system which sounded great.
Old Jan 20, 2016 | 10:31 AM
sridgett's Avatar
sridgett
I remember that ^^^ cool motor.
Old Jan 20, 2016 | 03:36 PM
NobbyClark's Avatar
NobbyClark
That is a lovely mk2 Fezz, Ford RS mad!!
tichy.cosworth
Nov 12, 2015 09:14 PM
155lee
Oct 13, 2015 11:27 PM
PaulT
Oct 10, 2015 02:33 PM
Russ Payne
Oct 9, 2015 02:51 PM
Fordmad!
Oct 7, 2015 11:29 PM
