Might be worth checking with a local Bosch auto parts dealer, if there is one near you? Ford might not do the whole thing, but, hopefully will do the rubber seal...
Cheeky ask, but, don't suppose you could tell me the part no. on the injector itself? I've got a spare set, but not 100% sure they're for an RST...
Thanks....
Hiya mate. The part number on my injectors is 0437502015. That's all I can see. On 1 of them. But bits of the number on the others. And they all look like the same number.
Hope it's of use to u mate
Thanks mate! Mine read 0437502047014 Don't know what the difference is, but, if the numbers not spot on, don't want to risk them being RST ones... I know, with a Cosworth type fuel pump, the last 3 numbers varied with the outlet. Banjo, push on etc.
Do they look the same U don't want to flog em just for the plastic sleeves do u ha ha ha can't find them anywhere
Mine don't have any sleeves!? Might be the difference in part no...? They're no use to me, so I may as well sell them. Prob have a look on Google and see what the part no. cross refers to...
