Mating st/rs duratec turbo to borg warner t5?
Old Oct 3, 2015 | 09:53 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Default Mating st/rs duratec turbo to borg warner t5?
Has anyone done the above?
Thinking about about putting a hyda duratec in to a rwd focus. Cossie engines now are silly money so looking for an alternative.
I would zetec but exhaust is on the the wrong side and the shell is tunnelled for exhaust on the other side.
Old Oct 3, 2015 | 11:26 AM
mk1turboestate's Avatar
mk1turboestate
Is it not the same bolt patten as zetec? If so direct fit but you will require a larger Capri thrust bearing ( I have the code somewhere )
Old Oct 4, 2015 | 10:00 AM
DixieTheKid
Pick-up P100 Power!
Being a volvo engine I wasn't too sure
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Rsmat
89
Oct 12, 2015 07:50 AM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
