Missfire when revving from cold
Old Oct 2, 2015 | 07:01 AM
L1AM_RS's Avatar
L1AM_RS
Default Missfire when revving from cold
Hi Guys,
Had a quick search on here but was unable to find anything regarding a missfire issue i have when the engine is revved from cold.
If left to idle on a cold start it idles perfectly fine, however when i apply the revs it doesn't like it.
Once warm its hunky dory, boosts well and idles fine.
Am i right in thinking i could have some form of coolant burning problem? If so i'd of thought it would misfire on start up regardless of the amounts of revs applied.
Any advice would be awesome.
Thanks
Old Oct 2, 2015 | 08:21 AM
Loomer's Avatar
Loomer
You need to monitor the AFR and discus this with your tuner, it may just be a case the cold start maps need some fuel raking out.
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
