Anyone know much about Deutsch connectors?
Wye Valley Hardcore
Need to buy a Deutsch AS Series connector for the engine loom but now I've been told I can't use 1mm2 cable with the pins?
I over-specced my loom in 1mm and 1.5mm thinwall so if that's the case I'm a bit stuck!
Can anyone confirm this?
I'm sure you can get 16 gauge terminals which is about 1.3mm.
http://www.ismotorsport.com/products...AS_Series.html
Pdf data sheet on here.
Make sure they stay in a dry environment. My experience of them is they are good at keeping the water out, but if any water does get in then it will be trapped in there and corrode the pins in no time. Assemble them with some non conductive grease will help too.
Wye Valley Hardcore
Cheers, Richie. Will bare that in mind. I need a minimum of 24 contacts just for the engine harness, but a few extra means I could also incorporate the Stack gauge wiring as well if need be.
Fudgey
Sep 17, 2015 01:06 PM
The Enigma
Sep 12, 2015 10:12 PM
