3dr cosworth starter motor
Old Sep 24, 2015 | 07:54 PM
cossie362's Avatar
cossie362
Default 3dr cosworth starter motor
Evening peeps
What options are available to replace my
Starter motor solenoid gets stuck when car is warm
Had a look on ebay just want to know which
One is the best to use. ?
Old Sep 24, 2015 | 08:55 PM
cossie09's Avatar
cossie09
Default Starter
Originally Posted by cossie362
Evening peeps
Hi.buy a 18td ford connect van one the starter fits the 2wd cosworth and is cheap to buy,hope this helps.
Old Oct 7, 2015 | 08:28 PM
Tim Wharton's Avatar
Tim Wharton
The cossie starter is quite esey to strip and repair
If you have a workshop manual it should give you an exploded view its proberbly just gumed up with clutch dust
You could just check the terminals on the solenoid are all clean and tight too
Cheers Tim
Old Oct 7, 2015 | 09:09 PM
james kiely's Avatar
james kiely
as said the transit connect one is the one to go for
Old Oct 11, 2015 | 03:53 PM
cossie362's Avatar
cossie362
Does it matter what year on the connect starter
Motor?
JK12
33
Apr 26, 2021 12:09 PM
3dr cossie
21
Nov 20, 2015 05:00 PM
CLIVE
Oct 2, 2015 12:58 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
