Brake servo/Master cylinder.
Ok, i've been trawling through the forums for an hour now and have yet to find a conclusive to any of my questions.
I've just removed the servo on my escort and it's definately seen better days.
Now I know people have used mk6 escort, mk2 mondeo servo's etc, with modifications. So what modifications are involved?
What servo / master cylinders are you using and what was required to fit them? (talk to me like im an idiot)
im in middle of doing mine you can also use mk3 but must have a mk3 m/s as the internals are different also if you use mk2 servo you can use a non abs m/s these are found on mk2 and mk1 as for the brackets I just used the mondy one and the escort on cut them apart and welded them together to suit
Well my mondeo servo and MC arrived. I honestly cant see how it would fit. The servo is 11.5" in diameter compared to the escorts 8". It fouls on the suspension turret.?!?
So it's back to the drawing board I think.
They have the brackets shortened so the servo fits nearer to the bulk head, message the guy I mentioned on my Facebook he will probably make you one, if need be you can post parts to me and I will deal with him at this end.
I posted some other links in your thread that you could try calling. However I don't think you'll have any luck finding one.
