1.6 cvh carb cam???
Originally Posted by sridgett
Any one know where I can get a standard cam for a 1.6 cvh on a carb for a good price???
What on earth is the point using a second hand cam in a cvh? They're scrap after 20-30k miles anyway, better getting a new one or a re-grind
I didn't realise u could still buy new ones for them. Was just offering the bloke some contact details lol, talk about shoot the fooking messenger
Second hand is pretty pointless as it will most likely be quite worn, if it isn't then make sure you get the lifters too and keep them matched to their respective lobes.
If you do go new then I recommend a Newman cam, other pattern part cams are very risky these days.
Cvh cams are practically a service item
im not shooting the messenger, it's your advice which isn't very good IMO, (sorry about that)as not only will it be worn to fook but you need the matched worn out lifters to go with it.
I never gave anyone any advice whatsoever I just passed on some contact details. And going on the subject of cvh cams I spent my entire youth working on them and having them as daily drivers and lost count of the amount of them I had to swap bits over to keep them running. In fact me and the guy I was apprentice to build a very early Zvh in year 2000 I think it was, I put a second hand cam in that out of a rotten xr3 and 15 years later that same engine is still going in the xr2 the engine ended up in and apart from regular servicing it's never gone wrong. But yeah your supposed to change cam and tappets for new or keep them matched but sometimes due to lack of availability of parts or funds then u do what u have to do.
no doubt it does run if you say so, but it will be scrap and won't have the same profile it went in with
really pleased you spent your entire youth working on them, it doesn't mean nobody else did.I took your post giving contact details for a breakers as condoning fitting a used cam? I'm sure that's what you meant? Apologies if not
15 years on the same cam in a cvh
Worked on it since new and always serviced it
For him. He did tell me that they do suffer from cam and tappet wear due to owners not changing the oil at the required intervals and not using the correct grade. The only other thing that used to cause accelerated wear was the old mechanical fuel pumps that used
To run off the cam and cars sat being unused for long periods of time.
Anyway just thought I'd share the conversation.
Incidentally I wasnt suggesting I was the only one who worked with cvhs when I was younger nor am I nieve to even think such a thing
It may still work but it won't be the same shape and won't produce the performance of a fresh grind.
You could service it every day and it would sti be scrap after 30k
Each to their own but back to my original post you'd have to be mental to use a second hand cam on a cvh unless it was a proper low power poverty build just to get it running
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
