Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Focus tddi problems
Old Sep 21, 2015 | 10:55 AM
markeh's Avatar
markeh
Default Focus tddi problems
Hi I am new to the forum, but have enjoyed reading them in the past.
The problem is that I have a small amount of air bubbles coming from the engine into the expansion bottle, eventually causing overflow, combined with a reasonable amount of steam exiting the exhaust.
There is no oil to water mix in coolant or engine, and there is no overheating.
I have recently replaced the water pump, cam belt, thermostat and radiator.
Head gasket or failed egr cooler?
Anyone have any thoughts
Thanks
Markeh
Old Oct 28, 2015 | 08:04 AM
markeh's Avatar
markeh
Default Sorted
Changed head gasket, no joy.
Bypassed egr cooler now back as it should be.
Old Apr 11, 2016 | 02:15 PM
MinxyMel's Avatar
MinxyMel
Default S-max water loss
Hi there. I've got a similar problem on our s-max, water level dropped so popped some more in to bring it up to the minimum line and when I parked the car up after having driven it 15 miles I realised water was coming out of the water tank and leaking over the car park. Now the level has dropped quite significantly and it's so hot in the water tank that it's bubbling and steaming. This can't be normal right? What do I do? Head gasket gone??
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 11:06 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
SteveyDee
Aug 24, 2015 05:43 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
