Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta mk6 crunching in second gear everytime
Old Sep 20, 2015 | 09:35 PM
DHMC's Avatar
DHMC
Default Fiesta mk6 crunching in second gear everytime
Hey guys, just bought a 03 fiesta as a project, sold with crunching second gear.
Any ideas if this is syncro/box related?
I can get a new box for £60 so I was going to drop one in but not sure if it could be anything else?
Old Sep 29, 2015 | 09:31 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Mine does it in first
Apparently it's a common issue so I'm driving it until it breaks
Old Sep 29, 2015 | 11:46 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
Sounds like a new gearbox and protect it with Shockproof oil from OPIE oils.
Old Sep 29, 2015 | 12:09 PM
RichieST's Avatar
RichieST
Could also be slack gear selection cables but I would expect it to crunch going in to other gears as well.
Old Sep 29, 2015 | 12:34 PM
_Jimmy_'s Avatar
_Jimmy_
Mine does it a bit when going into first while moving and also into second in winter before the gearbox has warmed up. Probably a worn synchro on second - have you tried rev matching or double de-clutching to see if that reduces the crunching? ...might help the box last a bit longer too
Old Sep 30, 2015 | 07:15 PM
tones61's Avatar
tones61
worn syncro,
try renewing gearbox oil for a good quality semi synth gear oil,
common fix for mitsi evo and vw boxes,
of which i have both owned and done,
rex647
Mar 6, 2022 06:20 AM
89barto89
Oct 4, 2015 06:59 PM
Mark_
40
Oct 2, 2015 04:40 PM
Marv888
Sep 26, 2015 03:44 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
