Valve stem seals
Old Sep 20, 2015 | 09:00 AM
RS-Rikki's Avatar
RS-Rikki
Default Valve stem seals
Got a 2 litre zetec turbo need to replace valve springs is there a guide or a special tool to compress the valve spring with out removing the head
Old Sep 20, 2015 | 10:34 AM
homer j's Avatar
homer j
As far as i'm aware the head needs to come off for a zetec.
Old Sep 20, 2015 | 07:56 PM
studabear's Avatar
studabear
I've seen a tool in a magazine which involves keeping the cylinders pressurized with compressed air to allow you to do the job, looked fiddly and iirc the tool was a good few quid too. Laser tools springs to mind.
Old Sep 21, 2015 | 04:20 AM
Chas's Avatar
Chas
You are closer than you think to being right .
Basically, you pressurise the cylinder at TDC using a leakdown tester. With the cylinder pressurised you can then remove the cams (preferably remove them before pressurisation) valve spring retainer and spring assembly before changing the valve stem seal. You have to be careful with this method that you don't drop the collets down the oilways etc ; covering the engine with a rag helps.
In theory you could pressurise the cylinder somehow via the spark plug aperture, retain that pressure and achieve the same result.
Old Sep 21, 2015 | 07:27 AM
studabear's Avatar
studabear
The tool I seen had a bracket that bolted to the head than a special lever to then compress the valve spring.
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
