Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Escort cab roof not closing properly
Old Sep 17, 2015 | 06:52 AM
Shaunc's Avatar
Shaunc
Default Escort cab roof not closing properly
Hi all
Having a problem with my cab roof. It is letting water in on the passenger side at the point where the roof and windscreen meet (see picture).
It doesn't pour in but its enough of a gap to let some water in when it rains heavy.
I've not had the car long and I think the previous owner has replaced the passenger side roof catch with one of a different model, as you can see in the pictures there is definitely a difference between the left and right catch. Is this normal? Or has it in fact been replaced at some point?
Thanks
Drivers side
Passenger side
Old Sep 17, 2015 | 12:18 PM
RichieST's Avatar
RichieST
Looks like the hook has been made, but certainly looks sufficient. Maybe loosen the lock nut off and try winding it in to pull the roof down tighter.
Old Sep 17, 2015 | 01:29 PM
Shaunc's Avatar
Shaunc
The hook part is screwed in as far as it can go. I might take it out and saw a bit off the end see if that works.
Cheers pal
Old Sep 22, 2015 | 06:38 PM
Shaunc's Avatar
Shaunc
It worked cutting it down cheers pal!
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
3drRich
Sep 13, 2015 07:32 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
