FRS Injector Spec
Old Sep 13, 2015 | 04:03 AM
NZWINRZ's Avatar
NZWINRZ
Default FRS Injector Spec
Does anyone know the spec of a stock FRS MK1 injector. I plan on installing the motor I built but will need to have the ecu remapped for larger turbo, cams, header etc etc. I don't know the cc's the injectors flows for the mapping into the new ecu. Anyone know??
Old Sep 14, 2015 | 06:11 PM
FRS#3425's Avatar
FRS#3425
About 440cc
Old Sep 14, 2015 | 11:58 PM
NZWINRZ's Avatar
NZWINRZ
Thanks, that will get me started.
What's the max power from the stock injector?
Are there any size larger that have the split spray pattern?
Old Sep 16, 2015 | 07:52 PM
RobbieBambino's Avatar
RobbieBambino
Think stock injectors start to max out about 320-340bhp and stock fuel pump starts to struggle to supply aswell, im running siemens 630cc injectors and DW fuel pump on and they easily cope with just over 400bhp
Old Jan 28, 2020 | 09:24 PM
Stu.H's Avatar
Stu.H
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
stevecfrst1
Sep 30, 2015 05:18 AM
