ZT inlet and cam cover.
Old Sep 7, 2015 | 04:08 PM
Chopshop85's Avatar
Chopshop85
Default ZT inlet and cam cover.
Got myself a blacktop with a 2.0 mondeo inlet. Bought a complete engine gasket set and it's got 3 lots of inlet gaskets. A metal one, a paper one and the little spade shape rubbers that fit around the ports. Questions is, which ones do I use?
Also, on a mk4 escort, does the cam cover fit or will it foul on the inner wing?
Old Sep 7, 2015 | 06:56 PM
studabear's Avatar
studabear
The cambelt cover will go in with modifications.
What gaskets are on your mondeo inlet? I used a frs mk1 inlet, that had the 4 rubbers inserts.
Old Sep 7, 2015 | 07:42 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Use whatever gaskets are for your inlet, if it has recesses for the rubber ones then use those for example.
Old Sep 7, 2015 | 07:56 PM
Chopshop85's Avatar
Chopshop85
What sort of modications? if it's a bit of a ballache I'll leave it.
Well I managed to bag a brand new complete mondeo inlet on ebay for £27!
So that has brand new rubber inserts. I just wouldn't have thought it would bolt straight onto the head using just those.
Thanks for clearing it up chaps.
Old Sep 7, 2015 | 08:09 PM
studabear's Avatar
studabear
The plastic upper part needs a notch cutting out to clear the inner wing/mount area. The alloy part needed quite a bit cutting off to allow it to fit in, you can only get the one bolt in to hold it in place once the engine is fitted, so I bonded it at the back end.
I can try and grab you a couple of pictures if you want, later in the week?
Old Sep 7, 2015 | 11:25 PM
Chopshop85's Avatar
Chopshop85
Sounds like a fair bit of work. I don't have any of the cam cover you see, but a friend is breaking a focus st170 and said I can grab whatever I need for free.
If you wouldnt mind putting a few pics up and i'll see how much is involved.
Old Sep 8, 2015 | 07:17 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Then grab the whole ST170 engine!!
Old Sep 8, 2015 | 09:53 PM
Chopshop85's Avatar
Chopshop85
Its lunched. It's why he's breaking the car. Which is a shame.
Old Sep 12, 2015 | 04:18 PM
studabear's Avatar
studabear
Old Sep 12, 2015 | 06:42 PM
Chopshop85's Avatar
Chopshop85
Thanks for that.
Nov 1, 2015 06:53 PM
