Diagnose problem plz
Old Sep 5, 2015 | 03:06 PM
rsturbo27's Avatar
rsturbo27
Default Diagnose problem plz
I'm having a lot of noise from drivers side wheel also clicking when I turn so jacked car up,the wheel has a lot of 9-3 movement but no half twelve movement,the driveshaft popped out a while back just pushed back in ? But the driveshaft now has a lot of movement all new track rod ends lower arms what is causing this to move so much as driveshaft not doing it on passenger side cheers forgot to say that the ball joint on lower arm is hitting back of disc there's that much movement which I think is causing the noise at speed
Old Sep 5, 2015 | 04:28 PM
stevos's Avatar
stevos
Sounds like a buggered drive shaft.
Is there any play in the steering rack arm or is the hub carrier where the ball joint bolts into worn.
Old Sep 5, 2015 | 04:51 PM
rsturbo27's Avatar
rsturbo27
Think it could be hub carrier as I can turn the driveshaft by hand quite a lot any idears cost to replace this with labour car is frst cheers
Old Sep 5, 2015 | 05:08 PM
stevos's Avatar
stevos
Not got a clue on fiesta parts for price mate but labour would prob be an hour max.
Can you not do it yourself.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
