Gauges, most important?
Old Sep 2, 2015 | 07:00 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Default Gauges, most important?
With the Lolvo project moving along nicely, I'm turning my attention to the inside, namely where to mount the gauges as "Q car" is key here, so no A pillar or dash mounted pods! So we're having to get creative, but it also means room is an issue in terms of how many we can fit.
Other than a boost and wideband, what else would you recommend to keep an eye on things? Oil pressure/temp?
Ben.
Old Sep 2, 2015 | 07:25 PM
Boost,air/fuel and voltage.
Cos500's Avatar
Cos500
Oil pressure for sure, I've got that plus oil temp and boost
Old Sep 2, 2015 | 07:40 PM
gcfcos's Avatar
gcfcos
Oil pressure, fuel/air, boost and I've wired up a separate voltage gauge to my fuel pump wiring so I can always check what voltage there is on boost, very handy on a Cossie!
Old Sep 2, 2015 | 08:11 PM
Sierrasideways's Avatar
Sierrasideways
This plus wideband
Old Sep 2, 2015 | 08:15 PM
Cos500's Avatar
Cos500
Originally Posted by Sierrasideways
This plus wideband
Didn't you sell those?
Old Sep 2, 2015 | 08:37 PM
simsytall's Avatar
simsytall
series 1
Oil temp,afr,boost
Old Sep 2, 2015 | 08:52 PM
Sierrasideways
I sold my spare set mate. These are on my car at the moment and will only leave when they break which knowing my luck shouldn't be too long lol
Philip.
Old Sep 2, 2015 | 09:00 PM
Cos500's Avatar
Cos500
Philip.
Sold em to me haha, they do look good although car still not finished
Old Sep 2, 2015 | 09:18 PM
Sierrasideways
O ya I knew your username rang a bell
Keep up the good work mate
I'm nearly there....beam, brakes and wheels....only 5 grand ffs
Philip.
Old Sep 3, 2015 | 07:48 AM
fraser9764's Avatar
fraser9764
Oil Pressure, Oil Temp, AFR and Boost.
Then a SECS monitor or similar ECU interface so you can check coolant temp, Air inlet temp, TPS Calibration etc.
Old Sep 3, 2015 | 07:54 AM
haz87's Avatar
haz87
Oil pressure, voltage and AFR IMO
Old Sep 3, 2015 | 11:03 AM
stevieturbo's Avatar
stevieturbo
C**t
If you want discreet, then get a multi function display.
Whether round or square type of dash.
PLX Devices do some nice round multifunction gauges, where one gauge can do pretty much anything, albeit you need separate control modules.
Old Sep 3, 2015 | 12:18 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
That's actually a cracking idea, good shout! Never looked into them though, what are the control modules for?
Old Sep 3, 2015 | 12:21 PM
stevieturbo
C**t
Each sensor requires a control module which then sends info to the gauge.
Or if the ecu in the car is OBD compliant, you can get it to display the data that way
http://www.plxdevices.com/category-s/109.htm
https://www.youtube.com/user/PLXDevices
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
