y reg mondeo 2.0 tddi wont start
Old Sep 2, 2015 | 03:02 PM
Rob Wells's Avatar
Rob Wells
Default y reg mondeo 2.0 tddi wont start
hi a mate of mine has this problem with his Mondeo estate when it first started it was diagnosed as egr faulty so we blanked it off then the car ran sweet for 2/3 days then cut out on him & wouldn't start. so he left it for 1/2 hours it then fired up and drove home. he went to it the next day started fine but cut out after half a mile and wouldn't start back up so we changed fuel filter for a genuine ford bled the system back up but still wouldn't start tried towing it and nothing. it will start with easy start but cuts out when you stop spraying any advice would be most appreciated
Old Sep 3, 2015 | 08:29 PM
chris cdti's Avatar
chris cdti
Checked the electric delivery pump on the drivers side of the tank?
Old Sep 3, 2015 | 08:42 PM
Rob Wells's Avatar
Rob Wells
We've checked this we've even put a live straight to it. Still nothing
Old Sep 3, 2015 | 09:32 PM
RichieST's Avatar
RichieST
Is the pump by the tank definitely working? They do fail quite often.
Check the wiring to the high pressure pump. Mine had a corroded wire there causing intermittent running. Give the wiring a wiggle while trying to start it.
Cam sensors are also pretty common to fail too.
Old Sep 4, 2015 | 08:34 AM
Rob Wells's Avatar
Rob Wells
It's showing the following codes
P0148
P0252
P1631
Old Sep 14, 2015 | 02:19 PM
Rob Wells's Avatar
Rob Wells
Thanks RichieST was the fuel delivery pump all sorted Ł30 off eBay happy days
Old Apr 18, 2023 | 12:19 AM
Ran's Avatar
Ran
Default Check injectors.
Sounds like an injector fault to me.
I had a very similar issue, car would start fine cold, once started even running for a few minutes it wouldn't start again until left to go completely cold. - often Hours later.
It ran like this for a good while, and then eventually wouldn't start at all.
I performed a leak off test on the injectors whilst cranking. One pot filled almost immediately.
Replaced that injector.
Problem solved.
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
