Help after rebuild
I'm after a bit of help the car is frst cvh was smoking bad (white) so had a rebuild new sleeves in pistons rings new valve seals new rings all new £1600 later but problem now is smokes white still on over run ? Question is I've also had turbo rebuilt at a cost of £345 but garage are now telling me it's turbo seals that causing it to smoke turbo has only done 50 miles since rebuild the breather system is set up all ok any advice plz as the dream is turning in a headache now cheers
On a tangent
Lot of variables in this so..
Has it been setup recently, and what management u running?
Is it running well generally, could be remanufacturing fallout burning off..
What colours the smoke, and is it doing it when warm,cold or all time?
When u rebuilt engine, had/has the exhaust been left full of crap, or been stored in damp place esp if stainless?
If all the above are good then from what u describe it does sound turbo related but if the fuelling's shit it can make it puffy so as long as the turbos been rebuilt properly then id be getting it checked over for fuelling, or if in doubt pull induction pipes off turbo and check for play/oil getting into exhaust...
Sorry cant be much more help, but if all the basics are good then its sounding
abit more indepth...
GOOD LUCK
GOOD LUCK
GOOD LUCK
GOOD LUCK
On a tangent
Well if its white it could be C/O not right, iirc I had an xr3i efi, used too white smoke almost like condensation in system, turned out co adjuster were shot...
New adjuster, no white smoke long chalk but worth a note imop..
Pull plugs and check no crystallized deposits on electrodes, indicating coolant getting in too system, when u had rebuild were head pressure tested and skimmed to be sure all well?
U sure all ya coolant circuits plumbed up right, heater working hot cold, oil breathers ok, no mayo deposits? Thermostat working?
Is turbo water cooled...could be a crack inside leaking into exhaust side..
Also id drop a bit of the oil out an check no water getting in as could be a crack internally..
Such a hard thing to diagnose, but if its running OFAB/FAC with a chip id get it checked over asap if your sure all I well elsewhere as these generic chips can be a nightmare if just slung in..
[QUOTE=rsturbo27;6620595]Yes head was skimmed and given all clear ok sound bit of advice there thank you I will get a set up done on her also any idear where I could get a co adjuster and are they easy to fit cheers also it's oil cooled turbo and had the upgrade straight from sump
Mc5506
Oct 5, 2015 09:57 PM
