Intercooler/rad package any good?
Keep seeing this on eBay as I look for the parts I need to finish the sapph, seems cheap but when other makes could cost double maybe more I wondered if anyone had fitted one?
http://pages.ebay.com/link/?nav=item...obalID=EBAY-GB
dont skimp at the end of your build mate. Get a proper cooler for it - i would for the AS top feed intercooler as that is one of the best as they copied the Spec R one.
Or at the very least go for the 60mm airtec cooler as that is almost as good as the top feed cooler according to the shootout they had
http://www.ebay.co.uk/itm/Ford-RS-Co...item19e644f8f0
Like this? I need one too,early Christmas present coming soon I think
Yeah I agree, just wondered what the differences would be against a proven one as the spec sounds ok
Be a long trek south to get set up
Either way you look at it - your car needs a new cooler and will need to be checked and setup after fitting anyway so you may aswell go for the better cooler or no point modifying your car for more power
A lot of people say their cooler is fine or that x works but unless someone monitors the intake temps then you don't really know and even if you do monitor then you need to check for power losses. When I spoke with spec r recently he said that in the past, many yrs ago, there were a few 500 bhp Cossies but they very quickly lost power when used as the intake temps were too high...the only real solution is to get it right first time around.
My car is being held back by the pace 500 style cooler and this was noticed when mapped, I need to solve this with a spec r or similar and have it bespoke made to my 205 engine bay and then re-mapped to suit.
