GT35 Turbo brace
Old Aug 31, 2015 | 08:28 PM
robbo9006's Avatar
robbo9006
Default GT35 Turbo brace
Sierra cosworth 2wd GT35 T4-8 T4 comp .70 A/R Turbine .96 A/R water&oil 500-600hp turbo turbocharger
I put this on my YB .
The exaust studs seem to be pulling away.
What strut brace are available.
I sold the baileys T3 brace.
I am hoping that would not fit as I sold it cheep.
Old Aug 31, 2015 | 08:44 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I had the same issue with my gt30 I had to make a support in the end
Old Aug 31, 2015 | 09:27 PM
robbo9006's Avatar
robbo9006
its ridiculous.
£125 for a Rs500 damper
£125 for a spec r 4wd head conversion.
I think the turbo needs the actuater bracket fitted as well.
Old Aug 31, 2015 | 09:31 PM
ajamesc's Avatar
ajamesc
This is what I did as I wasn't sure if the t range turbo braces would fit so I made this one
Old Aug 31, 2015 | 10:15 PM
robbo9006's Avatar
robbo9006
I can't believe ive spent hours on this.
That's a hanger.
Im after a damper.
My GT35 is pulling studs.
I need a spec r bracket for a 4x4 head,
A rs 500 turbo bracket.
All I need now are pictures of were the damper fits on the turbo.
Old Aug 31, 2015 | 10:24 PM
ajamesc's Avatar
ajamesc
Yeah a hanger to support the weight it don't need a damper. Once I fitted the hanger and a new set of lock nuts I had no more trouble
Old Aug 31, 2015 | 10:31 PM
robbo9006's Avatar
robbo9006
sound good.
The articles are saying the hanger doesn't work.
I have just sold a bailey damper.
I need to no were it bolts onto the turbo.
I have a external wastegate on a Chinese Gt35.
It does't have the actuater bracket.
I am thinking I will have to fit a actuater bracket and order a new baileys hanger.
I am still waiting for someone to turn up and offer me a solution.
Old Aug 31, 2015 | 10:35 PM
ajamesc's Avatar
ajamesc
Well from experience I can tell you they do work! My turbo had no mounting point so I removed one of the plates on the back of the compressor housing that was held on with 2x 13mm bolts. I then made a new plate that had a fixing point for a small rose joint which also bolted to the hanger. The hanger helped support the weight of the turbo which took the stress off the studs and nuts and stopped them coming loose
Old Aug 31, 2015 | 11:13 PM
robbo9006's Avatar
robbo9006
Well that's the easy option for me.
I just sold the baileys hanger as I don't like parts pilling up in the garage.
O well least I no it'll work as that's all I want.
stop pulling studs etc out of my head.
Old Sep 1, 2015 | 01:25 AM
Sierrasideways's Avatar
Sierrasideways
That's a hanger.
Im after a damper.
Above pic is my car.
This what you need?
The damper goes over this piece:
http://www.ebay.com.au/itm/251972413269
Philip.
Old Sep 1, 2015 | 10:50 AM
robbo9006's Avatar
robbo9006
So we have all 3 items required.
Thankyou.
Sanity has been reinstated.
Old Sep 1, 2015 | 02:10 PM
Sierrasideways
Happy days. Good luck with it mate.
Philip.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
