secs monitor
Old Aug 31, 2015 | 07:36 AM
cozzy jeff's Avatar
cozzy jeff
Default secs monitor
does anyone run one of these with wasted spark?
wired mine in yesterday and the Rev counter is under reading just like the original rev counter.
also throttle position shows 100% on tickover,tps is set as it should be so what's wrong?
Old Aug 31, 2015 | 02:09 PM
Loomer's Avatar
Loomer
There isn't much you can do about the tacho on the secs,
but check you have the correct tps selected in the secs menu
Old Aug 31, 2015 | 03:21 PM
cozzy jeff's Avatar
cozzy jeff
Didn't know you could select which tps you needed ,I'll look I to that.
Old Aug 31, 2015 | 03:23 PM
costina's Avatar
costina
Live long and prosper!!
My tachco on the secs does the same mate. Never tried to sort it. Done the rev counter mod tho that works fine.
Paul
Old Aug 31, 2015 | 04:14 PM
cozzy jeff's Avatar
cozzy jeff
my 3dr rev counter won't work with the "mod" it's currently with speedy cables to see if the can anything with it.
pabloXR
Sep 21, 2015 12:42 PM
Roscopeco
Sep 14, 2015 05:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
K42L
Aug 28, 2015 01:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
