mondeo tdci wont start
Old Aug 28, 2015 | 08:31 PM
Alun Gregory's Avatar
Alun Gregory
Default mondeo tdci wont start
Hi just new to the site
I have a 53 plate mondeo tdci 130bhp and cut out while driving and the glow plug light started flashing.
I have since had the injectors tested and had to replace all 4 and got them.re coded.
The car will still not start and I am now getting fuel presure at the fuel rail and I have had on fault code reader and keeps coming back with fault code 12 11 and 251
Old Sep 6, 2015 | 09:40 AM
Chas's Avatar
Chas
Have you changed your fuel filter? I would change that first, refill the filter with diesel and go from there.
ONLY get a genuine Ford filter, or if you really have to a Delphi or a Bosch filter without the E in the part no ; many will fob you off about the cheaper filter being 'good enough'. Cheap the above filters are not. Failure to put on a good filter can basically write off the car due to the dirt and parts breaking up going around the entire fuel system (injectors, pump, fuel lines etc.).
The genuine filters filter finer particles but they block up easier often leading to a no start situation...
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
Bailes1992
Sep 3, 2015 02:17 PM
kevin36
Sep 2, 2015 06:24 PM
