Cosworth v6 injector upgrade
Old Aug 28, 2015 | 11:18 AM
Russ Hill's Avatar
Russ Hill
Default Cosworth v6 injector upgrade
Hi I am after some advice for a mate of mine with a twin turbo cosworth v6 mini !!!! Running a emerald ecu and 6 triumph throttle bodies and twin plenum chambers
He has had it rolling roaded but it's running out of fuel flow from the injectors as they are standard cosworth ones . We have seen you can fit Vauxhall vectra v6 ones but we can only find ones where the fuel rail sits on top of the injectors and not on the side as there is not room above because of the inlet manifold.
So if anyone knows what side fed injectors will fit and also how to or what needs modifying on the fuel rail to fit the better injectors then can you please let me know
Many thanks in advance
Old Aug 29, 2015 | 03:13 AM
robrs2's Avatar
robrs2
Side feed injectors, Is it a BOB v6 ?
You can fit Nissan RB25DET or SR20DET injectors. RB25's are in sets of 6.
The standard ones will give you up to about 330bhp, depends on fuel pressure.
Or you can use Subaru yellow injectors. They are said to be 550cc or 440cc depends on the year. but in sets of 4 so you wil need two sets.
Also all the above will need different injector plugs fitting. I got two subaru inlet manifolds complete with wiring to do mine.
Remember to swap the o-ring seal from the ford ones to the others.
Rob
Old Aug 29, 2015 | 08:53 AM
doga-ot's Avatar
doga-ot
Mine has ford mustang 5.5 ltr yellow injectors
Old Aug 29, 2015 | 02:34 PM
Russ Hill's Avatar
Russ Hill
Thank you for the replies I will pass the information on to my friend who has the car . Any more tips or advice on what needs modifications to make different injectors fit the ford fuel rail are very much welcome
Old Aug 29, 2015 | 03:21 PM
RichieST's Avatar
RichieST
Think we need pics of the car!!
Old Aug 30, 2015 | 07:59 AM
Russ Hill's Avatar
Russ Hill
Old Aug 31, 2015 | 12:27 PM
Russ Hill's Avatar
Russ Hill
Hi are the mustang injectors you have used a direct replacement for the standard ones fitted . It's a bob engine if that helps and do you know the part numbers for them ?
Old Aug 31, 2015 | 12:37 PM
costina's Avatar
costina
Live long and prosper!!
Omg thats insane😎
So what power did it make?
Paul
Old Aug 31, 2015 | 03:20 PM
Russ Hill's Avatar
Russ Hill
From what I can remember my mate saying I think it was 300 odd and 340 flb of torque at a limited revs of 4200 by the guy running the rolling road until he can get the higher flow injectors
Old Aug 31, 2015 | 03:35 PM
Russ Hill's Avatar
Russ Hill
Oh by the way the whole car was built from scratch by my mate on a budget in his garage over the space of 5 years and it's still running a type 9 box . As far as we know this is the only bike throttle bodied twin turbo bob engine around
Old Aug 31, 2015 | 03:49 PM
doga-ot's Avatar
doga-ot
yes theyre a direct replacement!
Old Aug 31, 2015 | 06:44 PM
robrs2's Avatar
robrs2
BoB are side feed, mustang are top feed.
moesin2005
Jan 23, 2022 06:28 PM
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Aug 14, 2015 07:29 AM
