Are rolled front arches needed for 18's?
Old Aug 27, 2015 | 05:23 PM
turbotrev's Avatar
turbotrev
Default Are rolled front arches needed for 18's?
Got a set of 8x18 wheels to go on my saff, will be using 215/35 tyres and I believe they are an et35 offset.
My rear arches are already rolled but will I need the fronts doing?
The car is on koni shocks and springs and not crazy low
Cheers Paul
Old Aug 27, 2015 | 09:40 PM
jason_nike's Avatar
jason_nike
I had to roll my front arches, but rears are untouched
Old Aug 27, 2015 | 09:55 PM
Cosworth Lad's Avatar
Cosworth Lad
iv got 215 35 18s on mine . mines are fine iv got avo coils on mine
Old Aug 28, 2015 | 07:52 AM
Danielbetty's Avatar
Danielbetty
Cheers Paul
I ran 8x18s et35 with no issues at all,back on 17s now with et20 on the rear which people say will never fit but they do
Old Aug 28, 2015 | 09:18 AM
turbotrev's Avatar
turbotrev
Cool cool people.
Had a look at the new wheels and they appear to be et30.
Tried em on the car last night and they look like they should clear...
Cheers Paul
Old Aug 31, 2015 | 11:18 AM
cossynut2's Avatar
cossynut2
10 Year Member
Cool cool people.
Cheers Paul
Try them on full lock to make sure, as that is when they will rub on the arches.
I have got 335mm Hi-Spec brakes and my wheels have et35 offset and only just clear the calipers.
Old Aug 31, 2015 | 01:32 PM
Mine arnt rolled. Well not that i know of lol. Ive got 215/35/18 tyres on mine.
Old Sep 5, 2015 | 12:19 AM
cossiestu's Avatar
cossiestu
They look really good on yours Glenn! What suspension you running?
Old Sep 5, 2015 | 04:04 PM
Koni shocks and springs.
Old Sep 5, 2015 | 04:05 PM
Oh and thanks.
The car drives ok on these 18s too. Its not too harsh.
Old Sep 5, 2015 | 08:07 PM
jason_nike's Avatar
jason_nike
Mine are 360mm and also clear if that helps
Wheels are 8J, ET35
Old Sep 5, 2015 | 08:55 PM
doga-ot's Avatar
doga-ot
I have 17's 215/35 and i need my front rolled as i keep catching over big bumps i have konis (set to hard) with ahmed bayjoo springs
Old Sep 5, 2015 | 09:01 PM
cossiestu's Avatar
cossiestu
Quite fancy 18" Comps on mine, what suspension do you have Jason? I've got Koni shocks and springs on the back and Leda Coilovers on the front, so guessing it'll be ok? Arches are rolled at the front of the front arch, due to catching the tires where I set it up a bit too low to start with!!
Old Sep 5, 2015 | 09:35 PM
jason_nike's Avatar
jason_nike
Spax all round mate
Old Sep 6, 2015 | 10:27 AM
dojj's Avatar
dojj
Resident Wrestling Legend
The tolerances differed from car to car, what works on one might not work on another
Best thing to do is to remove the spring from the strut, refit everything and then turn the wheel from lock to lock with a jack underneath to see how far the suspension will travel before making any adjustments
Did that in mine and one arch needed rolling but the other was fine
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
muz
Aug 1, 2015 06:48 AM
