Wiring Diagram Request 4x4 Saph Cossie
Pick-up P100 Power!
Hi people. Does anyone have a car wiring diagram for a 4x4 saph cossie please. I've had a good look on line but unable to find out one. Thanks a lot.
Pick-up P100 Power!
Sharing is caring, if anyone needs more...for a 1992 model at least.
Dropbox linky
Air conditioning wiring is not directly applicable to either the DOHC or V6, as included in this one, but I can help with that if needed.
Dropbox linky
For a quick on the compressor clutch, look in the engine fuse box for relay R6. remove the relay to show the 4 connections. Standing at the front of the car, the two leftmost connectors (horizontal) are permanent power and clutch. short with some wire and you can hear the clutch operate. Start the car and see if you get cold air. You can also put a bulb or meter across the other two to see if the relay is trying to operate.
jdsjojo
Aug 30, 2015 07:48 PM
lukeeboy149
Aug 22, 2015 04:29 PM
