Fuel regulator
Anyone used the burton power fuel regulator? If so any good and easy enough to set up?
http://www.burtonpower.com/power-boost-valve-ford-sierra-cosworth-2wd-fsepbv384372.html
When I mapped vehicles (Cosworths or other), I always refused to map it when such a rising fuel rate regulator was present. Even when mapped perfectly there are no advantages over a standard regulator.
