Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Sierra 2.9 4x4 MAF's
Old Aug 24, 2015 | 03:58 PM
Graham S1's Avatar
Graham S1
Default Sierra 2.9 4x4 MAF's
Anyone know much about these?
Are they both supposed to have an adjustment screw in or just the front one?
My cable conectors are black at the front one, white at the rearwards MAF, that right?
How do you reset these? Can you wind the adjuster all the way in and then back out.
I had a slightly sticky flap, so I opened them up and put a little WD40 on the spindle bearing, and it now moves freely.
I have an exhaust gas analyser if that helps.
Recent full services, static timing set to 12 deg BTDC.
Can I test them with a multimeter?
yatta
May 21, 2016 10:31 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
