I need an rpm plus similar to that of the negative on a coil, as my cars EFI now I don't have a coil where could I pick it up? Don't rely want to use the Cps has I've had issues with it in the past and it's been replaced and rewired
If this is for the rev counter have a word with Karl as he has a nifty trick with a relay to use MFI rev counter with EFI. I think you have OFAM fitted too? in which case the ecu has a programmable tacho output as well as the EDIS output which is normally used in conjunction with a hard to find filter to remove a diagnostic pulse which EDIS sends.
either way, your ecu has various programmable outputs including tacho so could easily control water injection. Depending on which model you have (OFAM) you can also set whether the tacho out is 5V or 12V using an internal dip switch.
