rs rebuild nearly complete
Old Aug 11, 2015 | 06:34 PM
BlakeMoyle's Avatar
BlakeMoyle
Wish I had more time!
10 Year Member
Exclamation rs rebuild nearly complete
hi everyone ive just had my rs running for the first time in nearly 4 years! I was near actual tears! but have noticed the fan wont kick in and ive no instrument cluster at all not even trip computer, is there any advice from you chaps that could help resolve these issues im no mechanic and have done my best to do all the work myself but really stuck with the electrical side of things thanks in advance everyone who helps!!
Old Aug 14, 2015 | 07:17 AM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
I guess the first place to start is to check the simple things like fuses and relays, check all the earthing points are good and clean, look for any obvious broken wires etc.
Was it all working before, have you had the loom out?
Old Aug 14, 2015 | 05:31 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Hi there yes the loom was out got repaired and completely retaped then put back in, ive noticed I've got a single wire hanging behind the clock area it's two coloured red and blue I think(colour blind) but it has a yellow rectangular connector on the end but can't find out where it's goes and if it's anything to do with some of my issues?!?!
Old Aug 14, 2015 | 05:59 PM
Rob_DOHC's Avatar
Rob_DOHC
Do you have all the earth straps installed properly? Big earth cable running from battery to started motor bolt?
Do you own a multimeter? If not pop down to halfrauds or Maplins and get your self a cheap one as they are an invaluable tool for problems like this.
Old Aug 15, 2015 | 05:36 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
I think all the earth straps are in place, if I went to get a multi meter I wouldn't know how to use it?! Ha ha! Does any one know what the single two coloured wire behind the dash of for its got a yellow rectangle plug on it?
Old Aug 16, 2015 | 09:42 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Just thought I would try to get some photos up so you guys can see what I've been up to in the last 3 1/2 years!!
Old Aug 16, 2015 | 09:44 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Old Aug 16, 2015 | 09:46 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Old Aug 16, 2015 | 09:47 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Old Aug 16, 2015 | 09:50 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Old Aug 16, 2015 | 09:55 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Old Aug 16, 2015 | 10:22 AM
stickyslick's Avatar
stickyslick
Default Escort RS probs
Just read you post with interest you might find the following link helpful http://www.motorsport-developments.c...AF261_tech.pdf
Good Luck
Old Aug 16, 2015 | 11:03 AM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Cheers mate really appreciate it, been a long old slog was hoping to get a couple of weeks left of this years summer to drive her again but don't think that will happen now... Oh well there's always next spring I suppose, how do you think she's looking a lot better than when it was stripped down I'm hoping?!
Old Aug 16, 2015 | 04:02 PM
imnoteasy's Avatar
imnoteasy
Wow. Stunning.
I'm in the middle of putting one back together and was wandering where you got the sunroof trim and headlining from
Old Aug 16, 2015 | 04:06 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Great work look mint
Old Aug 16, 2015 | 06:33 PM
makaveli96's Avatar
makaveli96
Nice work.
Old Aug 16, 2015 | 08:36 PM
BlakeMoyle's Avatar
BlakeMoyle
10 Year Member
Thanks everyone for the comments it's been a real labour! The electrics are giving me a real hard time(push cigarette lighter in and the back wiper goes?!?!) the head lining I found on eBay by mistake!!?it was brand new old stock from a ford dealer in Glasgow came in the ford box the lot stamped sept 89! Got it for £35 buy it now!!! The sun screen was the original one out the car as was the grey trim round it, hoping my mate how sorted the loom can come from London ASAP to sort as it's kicking me right in the nuts!
Old Aug 23, 2015 | 01:27 AM
blackbeautyzetec's Avatar
blackbeautyzetec
Have you tried bridging the fan switch?
Old Aug 23, 2015 | 10:43 AM
james kiely's Avatar
james kiely
Fair play mate. You have done a fantastic job on it
Old Aug 23, 2015 | 06:27 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Superb work!
Wiring definitely sound like earthing problem (amongst other things).
Old Sep 1, 2015 | 08:33 AM
Rsmat's Avatar
Rsmat
Done very well so far ..you'll get there in the end ..sounds like earth problems
Old Sep 1, 2015 | 02:24 PM
jonny s2's Avatar
jonny s2
looking amazing!!
bobsworth
77
Mar 24, 2016 09:30 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
Steve Escos
Oct 1, 2015 06:57 AM
