Problem
Old Aug 3, 2015 | 05:26 PM
Tinshaw's Avatar
Tinshaw
Default Problem
Hi all need a bit help & advice.
On the way home from ford fair yesterday my speedo started playing up?
It was showing on 110 instead of 70? on average about 40mph out & bouncing
This has never happened before I pulled on the services to have a quick check on everything but all seemed fine, set off again & it started again??? If anyone could shed some light on this I would be grateful.
It's a staph cos 4x4
Cheers Lee
Old Aug 3, 2015 | 08:56 PM
jon@work's Avatar
jon@work
check your crank sensor
Old Aug 4, 2015 | 12:41 PM
Tinshaw's Avatar
Tinshaw
Why crank sensor out of interest??
Old Aug 4, 2015 | 03:53 PM
Marc sierra's Avatar
Marc sierra
Crank sensor has nothing to do with it. The speedo is driven mechanically from the front left drive shaft. It's probably the cable that is bent causing the speedo to wobble. And otherwise it would be the speedo itself.
Old Aug 4, 2015 | 04:26 PM
jon@work's Avatar
jon@work
you're right - I was thinking rev counter, not speedo
Old Aug 4, 2015 | 04:49 PM
Caddyshack's Avatar
Caddyshack
It is easy to remove the plastic drive. Check the speedo cable first but if it is the drive I have a spare that you can have...I think it's only 3 bolts but I cannot remember if you lose the front diff oil, prob would benefit from the change anyway.
Old Aug 4, 2015 | 08:41 PM
Tinshaw's Avatar
Tinshaw
Cheers caddy I'll have a look this weekend, I've only just put the diff oil in 2 lol
Old Aug 4, 2015 | 09:16 PM
Caddyshack's Avatar
Caddyshack
If the oil has only just gone I then no harm in getting it out clean and refilling.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
