Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
What would you do? New cylinder head? Escort Mk4 XR3i MFI
Old Jul 28, 2015 | 09:04 AM
LoveAnOldFord's Avatar
LoveAnOldFord
Default What would you do? New cylinder head? Escort Mk4 XR3i MFI
First post, hopefully I'm in the right forum
A compression test on my '89 F MFI XR3i Cabriolet revealed one piston has significantly less compression than the others, so now would be a good time for an upgrade.
I want to keep the car reasonably standard (no turbo or ZVH) but if the head is going to have to come apart is it worth spending a bit more and going for a fast road cam or a polished and ported cylinder head?
A rebuild (with a bit more power) was always on my list and I've got about £500 saved up, so my question is what would you do?
Old Jul 28, 2015 | 10:03 AM
haz87's Avatar
haz87
For £500 you won't get your bottom end sorted (most likely cause of low comp) and the head sorted.
A decent port and polish will cost you that alone.
Old Jul 28, 2015 | 10:18 AM
LoveAnOldFord
What if I just went standard? I've seen pricing at Specialised engines for a reconditioned CVH at sensible money.
Only problem is having Googled them, all I see is complaints about how shocking their work is.
Old Jul 28, 2015 | 12:32 PM
haz87's Avatar
haz87
I was going to say - avoid!
A CVH (n/a) rebuild can be done for sub 500 if you shop about and pick wisely but that would be DIY (other than any machine work required - likely a hone in this case but if rebore then costs start to add up)
JoeyBoyden
20
Aug 22, 2015 03:23 PM
turbotrev
Aug 22, 2015 11:41 AM
A.t.p
Aug 15, 2015 11:37 AM
Bobby9779
Aug 11, 2015 06:47 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
