mt75 4X4 gearbox, needs rebuild and a 2nd 4X4 box with no bellhousing
I have these sat in my garage not doing a lot and want them out the way,
1 COSWORTH 4X4 mt75 gearbox that was removed from my fiesta as it needs a rebuild, and I have a 2nd mt75 gearbox that is also in need of a rebuild but I removed the bellhousing from this 1 to use on a cosworth skyline box conversion I am doing
No gear lever cradle with these
Be good if you want to use the bellhousing for a skyline conversion or as spare box for a rebuild or build up a new gearkit without removing you box from your car while 1 is built up for you
£100 collected from Essex SS14
Can get pics if needed
Thanks
Marc
Thanks
Marc
matman
Sep 9, 2015 05:45 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
