fuel pump relay
Old Jun 21, 2015 | 07:26 AM
dlwarrior's Avatar
dlwarrior
Default fuel pump relay
Hi
Im on the look out for a series 1 fuel pump relay . can anyone point me in the direction of where to get one.
Or is there a way around it
thanks
Old Jun 29, 2015 | 10:16 AM
XR2's Avatar
XR2
Depends. Ford still stocks the pink relays which were also used for MK4 MFI Escorts. RS1600i had a different relay (black with a fuse on top) which is out of stock.
When you have trouble finding a correct one, you can also use any standard relay. But then you'll have to rewire it and might also use a different socket AND your fuel pump won't prime then.
Old Jul 3, 2015 | 09:17 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
unless you have a concourse type car I would fit a fuel pump re wire kit off the likes off matt lewis.
lets face it you could buy an expensive rare relay for it to fail in x amount of time or worse it dont work when you get it.
im constantly re wire pumps on many cars not just fords. They suffer with volt drops and high resistance at the best of times. 1v lower at the pump could cause a whole load of crap when tuning.
Old Jul 4, 2015 | 10:39 AM
marky_g's Avatar
marky_g
Fleet Manager
+1 for the rewire kit
Old Jul 5, 2015 | 08:42 PM
Vicar's Avatar
Vicar
Excuse my ignorance but what is the re wire kit?
Just had to replace the relay in mine
Old Jul 6, 2015 | 07:02 AM
Versus_Creations
Ask me a question!
exactly what it sounds like.
a kit that re wires the fuel pump uaing a new relay and loom so no power is used on old wires for fuel system.
Old Oct 26, 2015 | 07:01 PM
moesin2005's Avatar
moesin2005
do these do away with original relay and cant seem to find them on matt lewis site anyone have a link
Old Sep 21, 2016 | 10:12 AM
Steverobbo's Avatar
Steverobbo
Any help would be appriciated im in the same boat my relay has given up
Thanks steve
Old Sep 21, 2016 | 12:43 PM
costina's Avatar
costina
Live long and prosper!!
Thanks steve
I have 2 relays
Old Sep 21, 2016 | 01:18 PM
Steverobbo's Avatar
Steverobbo
Default Relays
Originally Posted by costina
I have 2 relays
Are they forsale ?
I would buy the pair are they silver
thanks steve
Old Sep 21, 2016 | 02:46 PM
costina's Avatar
costina
Are they forsale ?
thanks steve
Purple are they the same?
Old Sep 21, 2016 | 03:20 PM
haz87's Avatar
haz87
Purple are S2, different pin output/design to S1.
Think S1 shared the same relay as Golf GTi's of the era (16v i think... maybe 8) so VW sources/forums are a good shout too
Old Sep 21, 2016 | 03:26 PM
Steverobbo's Avatar
Steverobbo
Thanks for that I believe there is a conversion available
Old Sep 28, 2016 | 06:41 AM
sbeube02's Avatar
sbeube02
Hello, these relays are easily fixable if you are good at soldering. I have repaired several for friends.
Old Sep 28, 2016 | 11:33 AM
Steverobbo's Avatar
Steverobbo
Thanks for the info all running correctly now
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
155lee
Oct 24, 2015 11:11 AM
15
Oct 7, 2015 03:43 PM
tib2220
Sep 14, 2015 12:33 PM
