hand brake light
Old Jun 19, 2015 | 01:42 AM
hydro st170's Avatar
hydro st170
Default hand brake light
I have a 2003 focus st170 and now and againthe hand brake light will flicker on and of.Can anyone shed some light on what the problem is. Thanks
Old Jun 21, 2015 | 06:50 PM
mcst's Avatar
mcst
Low fluid/pads are low. There's a sensor on the reservoir, as the pads wear if the fluids a little low it will bring it on. If you've plenty of meat on the pads just top up the reservoir to the line. Can always dropper some out when you fit some more when the time comes
Old Jun 22, 2015 | 03:13 PM
hydro st170
The pads where changed bout 5 months ago but I recently handa new hand brake cable fitted would that affect the light? Ill check reservoir and c how it looks.What is the correct fluid to put in?
Old Jun 22, 2015 | 03:40 PM
mcst's Avatar
mcst
It will just be low fluid now the pads have worn a little. Think it's dot 4 but double check in your manual.
Check your cylinder isn't leaking too above your clutch pedal. It's a common problem, you'll have a wet carpet behind the pedal. Sure the 2 systems are linked iirc.
Old Jun 23, 2015 | 07:41 PM
hydro st170
Got it sorted it was just low fluid I have a stainless steel cover over the resoviour and cannt c the level without taking the lid of.I was told to put dot 5.1 in and he said it just has a higher boiling point and I read the bottle and it said it can be mixed with dot 3 or dotv4 so I put some in and prob sorted . Thanks for the advice people
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
Timmy74
Ford Mondeo Including ST
Aug 28, 2015 01:21 PM
