1987 Sierra xr4x4 help....
Old Jun 10, 2015 | 10:11 PM
Porkzilla's Avatar
Porkzilla
Default 1987 Sierra xr4x4 help....
Hey!
recently i traded my 91 sierra 2.0l dohc into a 87 xr4x4 that dosent run, the engine in the car is the 2.8i kjet
Well, the car does not want to start at all, it turns around very nice, but no sign of life, it backfires HEAVY if i press the gass, 1 time a flame came out of the exhaust.
the spark plugs are new, leads, and coil...
Iv checked the sparkplugs 3 times and they get wet, and iv checked for spark and the spark is very good, so what can be wrong now ?? I lined up syl 1 TDC and checked the dizzy, sat the ignition at 12 degree and still no life....
The car has run good all the years and the old owner parked the car and the next day it wouldent start...
Sorry for my english, im norwegian
Old Jun 11, 2015 | 08:59 AM
rdvil's Avatar
rdvil
All the plugs equally wet?
Old Jun 11, 2015 | 11:06 AM
Porkzilla's Avatar
Porkzilla
It looks like it yea. I can hear the fuel pump when i turn the key.
Old Jun 11, 2015 | 11:12 AM
dojj's Avatar
dojj
Resident Wrestling Legend
Fuel flap in the metering head or the cold start injector on the side of the plenum chamber
Disconnect this and see if it's any better
Old Jun 11, 2015 | 03:58 PM
Porkzilla's Avatar
Porkzilla
Where is the metering head ? nr 15?
Old Jun 11, 2015 | 08:50 PM
doga-ot's Avatar
doga-ot
Yep 15 is metering head!
Old Jun 11, 2015 | 09:53 PM
dojj's Avatar
dojj
And the thing above 35 is the cold start
It was normally blue from memory so just unplug the electrical connection
Old Jun 17, 2015 | 07:02 PM
Porkzilla's Avatar
Porkzilla
Ok an update, i managed to break a screwdriver's tip inside syl nr 1... but thats fixed, iv checked the timing, gapped the plugs, adjusted the timing to 12degress but still no start.... What's going on with the old girl :s how do i check the aux valve and metering head ? and the warmup regulator
Old Jun 17, 2015 | 07:52 PM
Porkzilla's Avatar
Porkzilla
I GOT THE CAR RUNNING! the fucking old owner had the dizzy 180 wrong! It fucking started at 1 turn
Old Jun 17, 2015 | 08:47 PM
dojj's Avatar
dojj
The simple things eh
Old Jun 17, 2015 | 08:55 PM
Porkzilla's Avatar
Porkzilla
yea, but i was kinda lazy after 12h work day so just made up this
1-5. 4-3. 2-6
The engine thinks syl 5 is 1 and 4 is 3 and so on runs like a charm now, going to fix it tomorrow.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
