No longer required as running a different setup now. for mk1 focus rs or blacktop zetec. Never fully fitted only pump test fitted in place but never run. Burton sell these for £1170 as seen here http://www.burtonpower.com/opi-exter...e-opidsk3.html
After £720 including poatage
Thanks.
Alex 07956647472
Im not sure on an S1....you need a bit of clearance for the pulley which sits in the middle of the crank pulley and for the pump itself which bolts to the aluminium part of the sump.
These are made by 'lacey' on here under the name 'OPI'. Awesome bits of kit and a great price at £800. I have fitted the same kit to my series 2 but had to remove the front anti roll bar and change to cosworth compression struts, as the oil pump fouls the anti roll bar. Just thought I'd share this info glwts
These are made by 'lacey' on here under the name 'OPI'. Awesome bits of kit and a great price at £800. I have fitted the same kit to my series 2 but had to remove the front anti roll bar and change to cosworth compression struts, as the oil pump fouls the anti toll bar. Just thought I'd share this info glwts
I thought there was clearance problems. Is that the same with a s1 antiroll bar set up?
I'm not sure but I would guess so. I can't see the anti roll bars being in a different position and plus the series 1 anti roll bar has a thicker diameter.
