cambelt change 1.8td
Old Jun 7, 2015 | 04:04 PM
molly4's Avatar
molly4
Default cambelt change 1.8td
how easy is it to fit a cambelt, engines out of car ta
Old Jun 7, 2015 | 06:00 PM
Colin_P's Avatar
Colin_P
These are easy to do, even more so if the engine is on the bench.
You will need some timing pins though. Its been a long time since I've done one but I seem to recall you can use drill bits instead of pins for the pulleys. I can't remember if you need need a screw in block pin on these though.
Depending how old it is as well, make sure you change any plastic idler pulleys to metal ones. Again, I can't remember the exact details but the old plastic pulleys breaking up used to cause a lot of these to go to the scrapper.... but that may have been on the older non turbo ones... it has been a long time.
Old Jun 7, 2015 | 06:44 PM
molly4's Avatar
molly4
Yer a star Colin P Many thanks for that
Old Jun 7, 2015 | 07:08 PM
chris cdti's Avatar
chris cdti
A plate goes in the cam to lock that, a screw in pin goes into the crank on the front of the engine that goes in once a 10mm is removed and I'm sure the fuel pump also as a pin as that's also timed up.
Old Jun 7, 2015 | 07:12 PM
molly4's Avatar
molly4
thanks chris wish me luck lol
Old Jun 7, 2015 | 08:00 PM
Colin_P's Avatar
Colin_P
Chris,
That is the case for an Endura E as fitted to the Focus and Connect. The engine is a newer version of the 1.8. Indeed the cam is locked with a flat bar once the rocker cover is off and a block pin for the crank and a pin for the pump. These are part chain, part belt setups with only one very short belt.
The older 1.8's with a separate pump and cam belts needed pins only, you didn't need to touch the rocker cover or lock the cam.
I could of course be wrong as it has been a long time since I did one.
Old Jun 7, 2015 | 09:10 PM
molly4's Avatar
molly4
thanks all for that when i get the lump out for the swop ill read more up on it ,thats if i dont give up on it lol
Nov 1, 2015 06:53 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
marky_g
Sep 12, 2015 04:26 PM
