Clearing out my toolbox yesterday and these bits are not needed by me so offering them on here.
Really good, clean dizzy. Un broken plug, clips still zinc colour, a quick wire brush and will be mint.
Comes with the dust cover inside, rotor arm and cap. Also have the shield for around it if wanted.
£35 delivered.
Mint dizzy phase sensor with perfect plug for ERST dizzy £15 delivered
Alloy Ford Racing bonnet spacers £10 delivered
Piper alloy vernier pulley £30 delivered
Steel vernier £20 delivered
Crank sensor brackets for the eec4 type sensors for custom setups £4 delivered each ( 9 of )
Crank trigger discs to suit cvh / Zetec bottom pulleys to weld on £20 each ( 2 of )
The pulley is shown as example
1800cvh crank sensor, bracket and modded trigger ring for weber conversion.
