Mk3 mondeo brakes what braided lines?
Old Jun 5, 2015 | 11:42 AM
marky_g's Avatar
marky_g
Fleet Manager
Default Mk3 mondeo brakes what braided lines?
As above what lines do I need? Will escort turbo lines be on it will I need something different?
Old Jun 5, 2015 | 05:13 PM
studabear's Avatar
studabear
IIRC my pal used the escort lines, I would ask him but he is on holiday.
Old Jun 5, 2015 | 07:00 PM
xrmalin's Avatar
xrmalin
I used the standard lines on mine
Old Jun 6, 2015 | 09:47 AM
marky_g's Avatar
marky_g
Fleet Manager
Excellent thanks
Old Jun 6, 2015 | 10:06 AM
bassboy's Avatar
bassboy
Hi Mark, did you use 12mm spacers on yours? If so where did you get them from?
Thanks
Old Jun 6, 2015 | 10:32 AM
dojj's Avatar
dojj
Resident Wrestling Legend
standard lines when i did mine
if you use the mondeo ones they are too long as i found when i did this on my fiesta
i took some pics when i redid them last week so i'll stick them up in a bit, no need for spacers i found other than the ones i used to make sure the mk6 wheels would fit as they are a different offset to the mk4 fiestas
Old Jun 6, 2015 | 11:58 AM
dojj's Avatar
dojj
some pics of when i did mine to the fiesta
that's all you need to do is drill out the holes to 12mm from 10mm for the bolts to go through
then everything should just bolt back into place
ive used longer studs because of the wheel i'm using
hope that helps
Old Jun 6, 2015 | 02:31 PM
marky_g's Avatar
marky_g
Fleet Manager
Thanks
i made them up out of some 6mm alloy plate i had was a right pain
Old Jun 6, 2015 | 07:27 PM
xrmalin's Avatar
xrmalin
Thanks
I knocked them up myself on the lathe in the garage which don't really help you
I'd of thought any engineering shop would be able to knock you some up I think I used 25mm diameter bar, drilled it up the middle & then parted them off at the right length.
Mark.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
Bighandsuk
Sep 2, 2015 05:23 PM
